E3D V6
Re: E3D V6
Post by jimc » Wed Mar 11, 2015 11:41 pm
for any of you guys in the past who have or are using my e3d mount and drive duct on thingiverse....i made a change. go on there and download the new bed cooling duct and print it. i made a couple tweaks to it so it sits centered on the heater block and gives a little more room for wires.
http://www.thingiverse.com/thing:344950
Bratag
Re: E3D V6
Post by Bratag » Thu Mar 12, 2015 1:38 am
jimc wrote:the firmware on the wiki is the correct firmware and is what would be on your machine right now. just pick the right one that applies. i think there are 4 different ones for different versions of the m2. the firmware change is easy. all you need to do is in the config h file is change the thermistor table to #5 so the temp reads correctly.
Well that seems simple enough. I take it that change needs to be made regardless of the 12v or 24v version? I'll put the order in tonight and print out the new and improved version of your drive / fan mount.
It never ceases to amaze me that you can print upgrades to a machine that you are upgrading etc etc.
Re: E3D V6
Post by jimc » Thu Mar 12, 2015 1:42 am
yes. the difference is that makergear and e3d use different thermistors so to read accurately they use a different table. its already built into marlin. you just need to set it to read the right one. goto the arduino website and download the software. you will open the firmware up with that program, make the changes then upload it to the rambo.
jdacal
Re: E3D V6
Post by jdacal » Sat Mar 14, 2015 12:14 am
jimc wrote:for any of you guys in the past who have or are using my e3d mount and drive duct on thingiverse....i made a change. go on there and download the new bed cooling duct and print it. i made a couple tweaks to it so it sits centered on the heater block and gives a little more room for wires.
Thanks Jim, this makes it perfect. The wires were my only issue with it and not a big issue at that as its been working great!
jdacal
Re: E3D V6
Post by jimc » Sat Mar 14, 2015 12:19 am
yeah it always worked but was just one of those things i know could be improved. just never got around to it. now that i have 2 m2's here i figured i would do it. i didnt want to print another round of hardware with the old style duct.
Bratag
Re: E3D V6
Post by Bratag » Sun Mar 15, 2015 5:02 am
Ok guys so my 24v version of the E3d arrived and after cannibalizing a molex connectors from my spares I have the thermistor and the heat element installed (I reused a spare one of those as well, keeping the one that shipped with the E3d as a spare).
After doing all this 2 things struck me
1) Why the hell did I bother ordering the 24 volt version when I just reused all the 24 parts from my spares
2) The 30mm fan that shipped with the kits was also 24v and that is different from the 40mm 12v version that blows on the standard v3b hotend.
Do I need order a 12v version of the 30mm fan?
Re: E3D V6
Post by jimc » Sun Mar 15, 2015 5:18 am
yep you should have just ordered the 12v version. you can take the cartridge heater right out of the v3b and put it in the new hot end, you need a 12v 30mm fan now.
Bratag
Re: E3D V6
Post by Bratag » Sun Mar 15, 2015 8:19 am
jimc wrote:yep you should have just ordered the 12v version. you can take the cartridge heater right out of the v3b and put it in the new hot end, you need a 12v 30mm fan now.
Yeah . It didn't cost any more for the 24v version but got a new 30mm on the way.Oh well it will give me time to get all the mounting stuff printed.
Bratag
Re: E3D V6
Post by Bratag » Mon Mar 16, 2015 10:15 pm
Jim on another note it seems to be that your filament drive perfectly lends itself to other attachments in addition to the fan shroud. My thought its it would be a great way to mount a machinists meter for easy bed leveling. Any chance you could provide the original design files. If not its fine I will bust out my limited modelling skills and a set of calipers :)
Re: E3D V6
Post by jimc » Tue Mar 17, 2015 1:03 am
Actually i have the snap on bracket as a seperate model so you can make what you want then just add the bracket to it, print it them it should snap right into place. I can guve ut to you in the original 3dm file for rhino or a step or iges.
