Yes, the smaller chain worked great for me, however, it does not allow for future expansion if additional cables need to be run. So keep that in mind when deciding which to use. I would recommend the .9" which jhaupt used in her build.jhaupt wrote:FYI, the part numbers for the cable chain and ends I meant to have in the PDF are 4516T46 and 4556T33, which is the .9" wide version for a .5" max cable bundle. Being jdacal found the smaller chain (parts 4516T44 and 4556T31) also work I've added a note in the PDF about using those instead and corrected my original numbers. Will upload it tonight.
~Justine
