MIC6 preorder number 2 *READY FOR SHIPPING*
Re: MIC6 preorder number 2 *READY FOR SHIPPING*
Hey Insta,
When do you think you can ship my order?
Thanks
Jerold
Thanks
Jerold
When did you place it?
November 8th. Looks like you are in the process of shipping. Received a shipped email from paypal yesterday. Very glad to see it coming from clear air of Kansas in to the smokey haze of Colorado where I live!.
Hey y'all voted to legalize it.CCRN wrote:November 8th. Looks like you are in the process of shipping. Received a shipped email from paypal yesterday. Very glad to see it coming from clear air of Kansas in to the smokey haze of Colorado where I live!.
I received the MIC6/PEI sheet today. I removed the small screw clips on my Rev E and secured the plate using larger binder clips. It then reset the starting height to the new plate using the M2E Z adjust app on my mac.
I let the machine heat up and started to send a print to the machine from octoprint. As the nozzle was purging, I noticed the bed was higher than the nozzle so when it would go to wipe it would have slammed into the plate, so I quickly powered down the printer to avoid the collision.
Here is my S3D staring script. i am going to run through setting the starting height again in the morning in case it is the problem. Can the script raise the bed higher than the starting height? Betting the starting height failed to save to firmware, but I'm not sure and figure I should ask.
Code: Select all
M108 S255 ; turn on M2 extruder fan
M201 X1000 Y1000 ; lower default accelerations
T1 ; switch to right extruder offsets for homing
G28 ; home all axes
T0 ; switch to left extruder
G1 X200 Y50 Z10 F9600 ; Move off platform
G1 Z0.4 ; Position nozzle above buildplate
G92 E0 ; zero extruder
G1 E60 F225 ; purge left nozzle
T1 ; Switch to right extruder
G1 X190 Z0.02 E1.0 F600 ; slow wipe left nozzle
;G1 Y40 ; y axis shift
;G1 X130 Z0.02 E1.0 F600 ; slow wipe right nozzle
G1 Z0.25 ; lift
Could be.....Unfortunately you're not going to be able to modify it from your starting script. You can either try resetting the Starting Height and level using the QuickStart Application, or you can try using the Z-Adjust Application again, or try just coding it using the codes that Steve has written up.CCRN wrote:Betting the starting height failed to save to firmware, but I'm not sure and figure I should ask.
For some reason it might not have stuck the first time, although that's the first time I've heard of that happening if it's been reset using the Z-Adjust Application. Usually that happens in the QuickStart App if you fail to follow through all of the leveling steps.
I am not familiar with these!Jules wrote:try just coding it using the codes that Steve has written up.
Took me a while to find it, since it went walkabout (chuckle!)...but here's the link to the discussion in the Z-Adjust App link:
viewtopic.php?f=3&t=3666
I set the starting height with the Z adjust app just now and the M206 echo shows
I checked the bed location at starting height and it shows -205.70
Hopefully it is properly set now. Heating up...
Also, what is the gcode command to echo the x/y/z current positions?
Code: Select all
M206 X0.00 Y0.00 Z6.85
I am up and printing on MIC6/PEI. Thank you very much Insta. Very happy to ditch the Aqua Net.
What temperature should I heat the bed to? I have been using 70C with boro.
