Post
by innkeeper » Mon Aug 03, 2015 5:39 pm
I've been following this thread for a bit... frankly i have some concerns about the approach.
to preface...i've been looking at the inductive solution for a bit as a retrofit on other printers..and now the m2 also.
The issues i see are:
- 5v is not reliable over time for this probe. what many do for other printers is run at a higher voltage, then use a voltage divider at the output to get the right 5v level out for the given supply voltage.
- for anyone running heated bed, the sensor is only rated to 50c, and there have been quite a few failures reported for those running heated beds over time.
- When it does fail, failures are not just on and off, but they either become less sensitive or erratic. (research this on other forums you will find these threads).
- Actual usage of the inductive probe, if you change beds, your z offset will have to change .. so in my case, i plan to swap off zebra plate, mic-6 and glass. so each time id have to modify the z offset, that seems to be a pain in the butt, and i know i will forget to do it.
My personal opinion is detecting the actual surface is much better over time than an inductive detection which is detecting the presence of metal, not its surface.
so id think the mechanical probe solution is better as you don't have any of those issues.
for my needs i am working on an implementation of a 3rd way, which is purely optical which would detect the surface of whatever the build plate is by reflection off the surface. the electronics shouldn't have any issues with thermal breakdown. - kind of the best of both words, non touch and detects the actual surface... still waiting on some parts...
please let me know if you think i am off totally base....
