nema17 dampers
Re: nema17 dampers
I ordered two of the dampers and mine come with a significant amount of the rubber molded out onto the mating faces of the metal (the face that goes against the motor and the other face that goes against the M2 chassis). Should I slice this off or will it not have any effect? The original link insta posted had no rubber on the mating faces and looks like it may have been taken off.
Re: nema17 dampers
Didn't notice any on mine....you can just slice it off, or try it with it on if it's level....might actually be quieter.
Re: nema17 dampers
i had some on mine, left it, and it didn't effect anything negatively, however it was quite thin.Calpoog wrote:I ordered two of the dampers and mine come with a significant amount of the rubber molded out onto the mating faces of the metal (the face that goes against the motor and the other face that goes against the M2 chassis). Should I slice this off or will it not have any effect? The original link insta posted had no rubber on the mating faces and looks like it may have been taken off.
Re: nema17 dampers
I seem to recall that the M2E is supposed to be quieter than earlier models. I don't find mine too objectionable, but I wouldn't mind making it quieter.
Has anyone with a "E" model tried the dampers? if so, how much difference did it make?
Re: nema17 dampers
Gwhite wrote:I seem to recall that the M2E is supposed to be quieter than earlier models. I don't find mine too objectionable, but I wouldn't mind making it quieter.
I'll tell you soon enough...just ordered some dampers for my X/Y steppers.
I have the printer set up in the room with my home theater, and would always avoid watching shows while a print was running.
Now I need to find fans that work with no modification so I can swap the fans to something quieter...any suggestions?
- willnewton
Re: nema17 dampers
viewtopic.php?f=10&t=3160&hilit=noctua&start=20
3rd post down on this page is where my fan install starts, but you should check out the whole thread.
Re: nema17 dampers
Just did it on my "E" printer last week. Yeah difference is huge, motors are silent nowGwhite wrote:I seem to recall that the M2E is supposed to be quieter than earlier models. I don't find mine too objectionable, but I wouldn't mind making it quieter.
I am a little concerned about belt tension tho. I can't get it as tight as it was from the factory no matter how hard I push, but it seems to print fine. Y axis motor was a pain to mod, I had to move pulley very far up the shaft, almost worry that it might slip off.
I don't think there's any way to put damper on Z axis motor btw, it's touching bottom as it is. Not that you need damper on that one
Re: nema17 dampers
I just took mine off... While noise reduction was awesome, my belts kept on loosing their tension. There's just no way to get it tight with rubber damper moving stepper. Maybe rubber wasn't of good quality on mine, but I decided not to risk it as I use this printer commercially and quality is priority...
Re: nema17 dampers
My dampers didn't reduce the noise as much as I was expecting, but it's still reduced. Now to start printing stuff so I can see if it causes any issues there
Re: nema17 dampers
I have had dampers installed on my M2E X and Y axis for about a year and the difference is pretty big in the noise department and there have not been any problems even having only two bolts tying the motor to the frames.
