nema17 dampers
Matt_Sharkey
Re: nema17 dampers
Post by Matt_Sharkey » Mon Aug 17, 2015 8:22 pm
Ever since I installed dampers, I have been getting more belt skips, 2 today had me pretty mad. Seems the dampers allow the motors to torque a few degrees into the belts, not guarenteeing a great grip on the belts. I can't seem to get them tight enough, particularly the x axis.
I have my travels set to 250mm/s and the Acceleration set to 800.
any advice?
Slipshine
Re: nema17 dampers
Post by Slipshine » Mon Aug 17, 2015 11:09 pm
You might want to examine the dampener to make sure it is not cracked in the rubber.
Or no longer bonded to the steel parts.
Farr0wn3d
Re: nema17 dampers
Post by Farr0wn3d » Tue Aug 18, 2015 12:59 am
ednisley wrote:
innkeeper wrote:reproduce it if I get the homing speeds at the right speed
Two words: mechanical resonance
The rule of thumb for fixing that involves avoiding that particular speed, which is easy enough for 3D printers that never move at the same speed in the same direction for very long. Set the homing speed to another value and the problem will Go Away.
And it doesn't affect print quality, because the resonance takes longer to build up than typical printing moves will allow.
If I'm ever having a day thats a little too good, I'm gonna PM Ed to let him deflate my enthusiasm. ;)
Re: nema17 dampers
Post by insta » Tue Aug 18, 2015 2:23 am
Matt_Sharkey wrote:Ever since I installed dampers, I have been getting more belt skips, 2 today had me pretty mad. Seems the dampers allow the motors to torque a few degrees into the belts, not guarenteeing a great grip on the belts. I can't seem to get them tight enough, particularly the x axis.
any advice?
They do allow a bit of flex, but it sounds like you got a bum one :(
Re: nema17 dampers
Post by ednisley » Tue Aug 18, 2015 2:23 am
Farr0wn3d wrote:PM Ed to let him deflate my enthusiasm
Suffice it to say I've made mistakes so vast that none survive to tell the tale... [sigh]
innkeeper
Re: nema17 dampers
Post by innkeeper » Thu Aug 20, 2015 3:11 pm
I'll second that... i think you have a bad one.
i was a bit paranoid about them and abused them when i first got them to see if i would have problems, and simply couldn't get the m2 to mis behave with them even at high acceleration.
M2 - Smoothieboard Electronics - Upg Z stepper - IR auto bed leveling - Astrosyn dampers X/Y/Z - MIC 6, Zebra and PEI .25 Build Plates - Pico, E3D, V3B Hotends - Plastic and metal Extruder blocks, 24v Upg, - GLCD Smart Controller - other 3d printers
Re: nema17 dampers
Post by Jules » Sun Aug 23, 2015 9:43 pm
Whoa insta - you done good dude! :D
Finally put the dampers on (got tired of waiting for hubs to assist) and while I noticed absolutely no difference in the noise level, (all I could ever hear was the fans anyway - mine was pretty tight), I noticed a BIG difference when printing infill for thin walls. My M2 used to jog all over the place when doing thin wall infill, and now ..... Baby don't dance no more! Running my first print now and it's tight as a drum!
Good call on these things! Very glad I got 'em! :D
Vandal968
Re: nema17 dampers
Post by Vandal968 » Tue Aug 25, 2015 2:28 am
Dampers arrived today, WOW! What a difference!!!!!
Thanks Insta!
c
Re: nema17 dampers
Post by jsc » Tue Aug 25, 2015 5:01 am
Sigh. I was resisting, but with all the raves I find I can no longer. Anyone have an extra pair left over that I can buy off you?
Re: nema17 dampers
Post by insta » Tue Aug 25, 2015 5:22 am
I got mine here, they were quick to arrive: http://www.ultibots.com/nema-17-damper- ... y17rmdamp/
