Just to make sure I understand, these are the screws through the holes on the side of the pulley's body?jdacal wrote:you might want to loosen the allen screw on the pulley first since you'll have to adjust the pulley
nema17 dampers
Re: nema17 dampers
Re: nema17 dampers
Sorry for the late reply but yes, the tiny allen screw that holds the pulley on the shaft.nirfriedman wrote:Just to make sure I understand, these are the screws through the holes on the side of the pulley's body?jdacal wrote:you might want to loosen the allen screw on the pulley first since you'll have to adjust the pulley
Re: nema17 dampers
I did find one negative to the dampers. The chassis acts as a heatsink for the motors, so when you switch to the dampers the motors do run hotter since their is no longer a metal to metal connection to the chassis. My Z motor now runs cooler than the X and Y. But I don't think its a huge issue, at least not on mine with the heat sinks I have on them.
Re: nema17 dampers
Neary all steppers naturally run hot if there running near or at spec.
Steppers i currently see designed to work up to 80c as an operating temperature.
I've got a slightly modified setup, but my hottest stepper is 60c and i am using dampers. Personally, id not get to bothered unless i was approaching that 80c mark.
Re: nema17 dampers
Its not a lot, mine are running at 52C with the heatsinks, the drive stepper is at 50C (also has heat sinks). That was about 7 hours into a 9 hour print. Z is at 48C
I originally thought it was a lot more as they felt much hotter on my thumbs, measured them after the original post.
Re: nema17 dampers
Even without the heatsink effect of the frame, you'd never be able to overheat the motors before the drivers burn up. One of my cnc mills uses steppers and it's in my garage in Phoenix so it is often at 110F before I even turn it on. It will be fine, enjoy the newfound silence and don't worry about it. Cheers, c
Re: nema17 dampers
Just installed mine. Like everyone else who has put them on, I'm astonished by the difference. Unlike the people throwing on Noctuas for extra quiet, though, I went the other way and put on the loudest buzzsaw fans I could find, so the total noise reduction isn't as much as it could be when they kick in. Still, white noise is better than a high pitched whine.
Re: nema17 dampers
I've got two Noctua's coming in tomorrow, can't wait. Its going to be eerie, all that motion with so little sound. I'm going to try putting a 30-40mm fan adapter on JimC's e3d drive and stepping down the RPM's on the 40mm fan.
Re: nema17 dampers
I just got back from a trip and found this fan waiting for me from Amazon. This Noctua uses a 4-wire PWM cable rather than a 3-wire like the 40mm fans. The connector in the MakerGear power supply is only two pins and there is no combination of adapters that allows you to wire it in without splicing. I had to use two of the splicing connectors that came with the 40mm Noctua fans (the 60mm doesn't include them). Although the fan itself is silent, sound reduction once it's all assembled is about 50% compared to stock. I think it's because of noise generated sucking air across the holes in the PSU cases (inner and outer). A definite, noticeable improvement, but nowhere near the miraculous difference made by swapping the 40mm fans & ditching the MakerGear fan shrouds (probably 90% quieter) and it's quite a bit more effort (there are about a million screws involved in opening the power-supply). YMMV (but probably not).Vandal968 wrote:I just checked, it's a 60mm 12v fan. This should be the correct replacement, I'll know for sure on Tuesday.
http://www.amazon.com/gp/product/B009NQ ... ailpages00
cheers,
c
cheers,
c
Re: nema17 dampers
Thanks! it was much easier than I thought it would be, and the printer now cannot be heard from the other roomjdacal wrote: Sorry for the late reply but yes, the tiny allen screw that holds the pulley on the shaft.
