Pt100 upgrade problems
Posted: Wed Aug 19, 2015 9:34 pm
Hi, I have a later 24v M2 with and E3D hot end. I recently bought a kit from E3D which replaces the thermister with a PT100 sensor and amplifier board. Here is the link: http://e3d-online.com/V6-PT100-Sensor-Kit.
Anyway, I am using the latest standard firmware for the M2. There is no provision for a PT100 sensor so what I did was go into the latest general release of Marlin and copy the table for what seems to be the appropriate sensor. I reproduced what I copied below. I placed it into the existing standard M2 firmware "thermistorstables.h". I then sent the appropriate sensor value to "20" in configuration.h. I wired up the board so that the "signal" and "0v" wires come from the original sensor connector on the rambo board. I then ran a jumper from an auxillary 5v pad on the rambo board. My meter shows 5v between the 0v and 5v pins on the amplifier. The firmware compiles with no problem and the printer connects to simplify 3D without a problem. The issue is that the extruder stays pegged at 50 degrees and the bed remains at 31 degrees. Does anyone have any suggestions? I am in the process of contacting E3D but I am thinking that some of this is makergear specific.
Thanks,
Mike
Here is the additional code that I added to the existing makergear firmware:
#if (THERMISTORHEATER_0 == 20) || (THERMISTORHEATER_1 == 20) || (THERMISTORHEATER_2 == 20) || (THERMISTORBED == 20) // PT100 with INA826 amp on Ultimaker v2.0 electronics
/* The PT100 in the Ultimaker v2.0 electronics has a high sample value for a high temperature.
This does not match the normal thermistor behaviour so we need to set the following defines */
# define HEATER_0_RAW_HI_TEMP 16383
# define HEATER_0_RAW_LO_TEMP 0
#endif
#if (THERMISTORHEATER_1 == 20)
# define HEATER_1_RAW_HI_TEMP 16383
# define HEATER_1_RAW_LO_TEMP 0
#endif
#if (THERMISTORHEATER_2 == 20)
# define HEATER_2_RAW_HI_TEMP 16383
# define HEATER_2_RAW_LO_TEMP 0
#endif
#if (THERMISTORBED == 20)
# define HEATER_BED_RAW_HI_TEMP 16383
# define HEATER_BED_RAW_LO_TEMP 0
#endif
const short temptable_20[][2] PROGMEM = {
{ 0*OVERSAMPLENR , 0 },
{ 227*OVERSAMPLENR , 1 },
{ 236*OVERSAMPLENR , 10 },
{ 245*OVERSAMPLENR , 20 },
{ 253*OVERSAMPLENR , 30 },
{ 262*OVERSAMPLENR , 40 },
{ 270*OVERSAMPLENR , 50 },
{ 279*OVERSAMPLENR , 60 },
{ 287*OVERSAMPLENR , 70 },
{ 295*OVERSAMPLENR , 80 },
{ 304*OVERSAMPLENR , 90 },
{ 312*OVERSAMPLENR , 100 },
{ 320*OVERSAMPLENR , 110 },
{ 329*OVERSAMPLENR , 120 },
{ 337*OVERSAMPLENR , 130 },
{ 345*OVERSAMPLENR , 140 },
{ 353*OVERSAMPLENR , 150 },
{ 361*OVERSAMPLENR , 160 },
{ 369*OVERSAMPLENR , 170 },
{ 377*OVERSAMPLENR , 180 },
{ 385*OVERSAMPLENR , 190 },
{ 393*OVERSAMPLENR , 200 },
{ 401*OVERSAMPLENR , 210 },
{ 409*OVERSAMPLENR , 220 },
{ 417*OVERSAMPLENR , 230 },
{ 424*OVERSAMPLENR , 240 },
{ 432*OVERSAMPLENR , 250 },
{ 440*OVERSAMPLENR , 260 },
{ 447*OVERSAMPLENR , 270 },
{ 455*OVERSAMPLENR , 280 },
{ 463*OVERSAMPLENR , 290 },
{ 470*OVERSAMPLENR , 300 },
{ 478*OVERSAMPLENR , 310 },
{ 485*OVERSAMPLENR , 320 },
{ 493*OVERSAMPLENR , 330 },
{ 500*OVERSAMPLENR , 340 },
{ 507*OVERSAMPLENR , 350 },
{ 515*OVERSAMPLENR , 360 },
{ 522*OVERSAMPLENR , 370 },
{ 529*OVERSAMPLENR , 380 },
{ 537*OVERSAMPLENR , 390 },
{ 544*OVERSAMPLENR , 400 },
{ 614*OVERSAMPLENR , 500 },
{ 681*OVERSAMPLENR , 600 },
{ 744*OVERSAMPLENR , 700 },
{ 805*OVERSAMPLENR , 800 },
{ 862*OVERSAMPLENR , 900 },
{ 917*OVERSAMPLENR , 1000 },
{ 968*OVERSAMPLENR , 1100 }
#endif
Thanks,
Mike
#endif
#endif
#endif
#endif
#endif
