Not sure if this is what your talking about but in S3D I got thisJosh wrote:sthone - what does the firmware echo back when you connect to the printer now? And what does it echo back if you send "M119", with no endstops activated, vs. pressing the Z Max endstop by hand?
Attempting connection at \\.\COM3...
RECEIVED: start
Connected to machine!
RECEIVED: echo:Marlin1.0.2
Marlin1.0.2
SENT: T0
RECEIVED: echo: Last Updated: Dec 19 2015 16:00:11 | Author: (MG|Josh, M2 General - AWBG3 v001 11/30/2015)
RECEIVED: Compiled: Dec 19 2015
RECEIVED: echo: Free Memory: 4005 PlannerBufferBytes: 1232
RECEIVED: echo:Hardcoded Default Settings Loaded
RECEIVED: echo:Steps per unit:
Steps per unit:
RECEIVED: echo: M92 X88.88 Y88.88 Z400.00 E471.50
RECEIVED: echo:Maximum feedrates (mm/s):
RECEIVED: echo: M203 X500.00 Y500.00 Z25.00 E25.00
RECEIVED: echo:Maximum Acceleration (mm/s2):
RECEIVED: echo: M201 X9000 Y9000 Z100 E10000
RECEIVED: echo:Acceleration: S=acceleration, T=retract acceleration
RECEIVED: echo: M204 S3000.00 T3000.00
RECEIVED: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
RECEIVED: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
RECEIVED: echo:Home offset (mm):
Home offset (mm):
RECEIVED: echo: M206 X0.00 Y0.00 Z0.00
RECEIVED: echo:PID settings:
PID settings:
RECEIVED: echo: M301 P25.89 I1.94 D86.53
RECEIVED: echo:SD card ok
RECEIVED: echo:Active Extruder: 0
Active Extruder: 0
RECEIVED: ok
End stop NOT pressed -
SENT: M119
RECEIVED: Reporting endstop status
RECEIVED: x_min: open
RECEIVED: y_min: open
RECEIVED: z_min: open
RECEIVED: z_max: open
RECEIVED: ok
End Stop pressed -
SENT: M119
RECEIVED: ok
Nothing showing triggered
Does this look right for the connection???
