Quieter Fans
kartcrg
Re: Quieter Fans
Post by kartcrg » Wed Dec 09, 2015 4:10 am
Pekish - it says the A4X10 FLX is 5 volts? http://www.amazon.com/noctua-NF-A4X10-F ... +A4x10+FLX
Pekish79
Re: Quieter Fans
Post by Pekish79 » Wed Dec 09, 2015 4:36 am
no there are 2
one is the 5v and is wrong
the otehr one is the FLX 12v
http://noctua.at/en/products/fan.html
http://www.amazon.com/40x10mm-Bearing-P ... octua+40mm <<<< THIS ONE
the 5V say 5V on amazon (WRONG ONE)
http://www.amazon.com/noctua-NF-A4X10-F ... octua+40mm
Pekish79
Re: Quieter Fans
Post by Pekish79 » Wed Dec 09, 2015 4:41 am
Mach wrote:I recently changed out the extruder and electronics fan for the 40mm Noctua. I bought the Noctua 60 as well but thought cracking the internal case on the power supply more than I wanted to tear into.
I did replace the the 50mm bed fan with a 15x50 24V blower instead of the 50mm fan. So far I'm happy with the noise level and performance. I did so based on this Reddit thread https://www.reddit.com/r/3Dprinting/com ... ud_fan_vs/. I'm still testing and need to make a duct for it but so far so good.
the blower i see there in that thread is 12V make sure urs is 24V
A 50mm Blower fan.
I bought this one: http://uk.farnell.com/sunon/gb1205phv1- ... dp/1568490
50mm x 50mm x 15mm
12V
the other one they link is
http://www.amazon.com/gp/product/B00MJU ... ge_o02_s00
as well 12V
Mach
Re: Quieter Fans
Post by Mach » Wed Dec 09, 2015 4:48 am
Thanks for the heads up. This is the one that I got:
http://www.amazon.com/gp/product/B00W8W ... ge_o09_s00
Pekish79
Re: Quieter Fans
Post by Pekish79 » Wed Dec 09, 2015 4:57 am
^_^ that is perfect
kartcrg
Re: Quieter Fans
Post by kartcrg » Wed Dec 09, 2015 5:23 am
Thanks dude. Sucks they're ugly and not black haha.
Re: Quieter Fans
Post by jsc » Wed Dec 09, 2015 8:57 am
In a previous fan thread, someone pointed out to me that blower fans actually throw out air centrifugally, in the same plane as the rotation of the blades. So you will need to work out some mount for it, it is not a simple replacement part. They are also best for high static pressure/low CFM, so would work better with some sort of fan duct.
helifrek
Re: Quieter Fans
Post by helifrek » Fri Feb 05, 2016 11:05 am
http://www.frozencpu.com/products/9349/ ... tml?tl=g33
Found this, only 11 dB but also only 2.9cfm airflow.
willnewton
Re: Quieter Fans
Post by willnewton » Sat Feb 06, 2016 4:38 am
For all the trouble finding the the correct voltage quiet bed fan, couldn't a voltage divider be used? I just wired one for my leveling probe and it works fine for dropping 12v to 5v.
If you start with a 24v input and add two 10k resistors and you halve the output to 12v.
https://en.m.wikipedia.org/wiki/Voltage_divider
I am not an electro-guru so may be missing something in this simple solution.
Re: Quieter Fans
Post by jsc » Sat Feb 06, 2016 5:41 am
That only works if there is no other load in the circuit, like a fan.
