E3D V6
Re: E3D V6
Post by jimc » Sun Mar 22, 2015 1:59 am
Yeah usually but not all the time. I set the width to whatever i need for the particular model im printing.
Lateralg
Re: E3D V6
Post by Lateralg » Sun Mar 22, 2015 5:32 pm
I meant to say extrusion width, but I think you answered my question.
Gary
Make Better Things
Make Things Better
JohnnyRobot
Re: E3D V6
Post by JohnnyRobot » Mon Mar 23, 2015 6:15 pm
So the E3D V6 is really peaking my interest at the moment.
I've even found a distributor that will allow me to select a 24V version. Correct me if I'm wrong, but would this mean, "plug-n-modify-firmware-n-play"?
  • 1 x 100K Semitec NTC thermistor
  • 12v 40W Heater Cartridge (24v/25w available upon request)
  • 1 x 12v 30x30x10mm fan (24v available upon request)
  • 1 x Thermistor wire (1000mm)
  • 2 x 0.75mm Ferrules - for Solder-Free Wire Joints
-- Hi! No signature here.
Re: E3D V6
Post by jimc » Mon Mar 23, 2015 6:41 pm
For the most part yes. If your ordering a 24v heater then be sure you get a 12v fan. Usually if you order 24v then the fan will be as well. You dont want that. You would also need to print my e3dv6 filament drive setup or someone elses. The v3b heater cartridge is standard size and will slide right into the e3d heater block as well so you can save the new one for down the road. Only thing extr you need to order are some molex connectors to put on the fan, heat and thermistor wires so it plugs into the m2. Makergear has them or you can order from newark, mouser or wherever. There is a thread here somewhere with the part #s
PcS
Re: E3D V6
Post by PcS » Mon Mar 23, 2015 8:21 pm
I would really give the makergear v4 a look . It is a plug and play kit and I have not had one single problem with it since Install. Heats extremely fast and nozzle and filament changes are a breeze.
JohnnyRobot
Re: E3D V6
Post by JohnnyRobot » Mon Mar 23, 2015 8:55 pm
I have, and I've been torn between the two for a while now... Ugg.
What area of Michigan?
PcS
Re: E3D V6
Post by PcS » Mon Mar 23, 2015 10:47 pm
Battle Creek area ! :D
JohnnyRobot
Re: E3D V6
Post by JohnnyRobot » Mon Mar 23, 2015 11:14 pm
Bummer... I'm Southeast (Rochester)
I was going to ask if I could come over and see the V4 extruder in action. :geek:
Lateralg
Re: E3D V6
Post by Lateralg » Mon Mar 23, 2015 11:52 pm
I'll be half way in Howell.
Gary
Make Better Things
Make Things Better
PcS
Re: E3D V6
Post by PcS » Tue Mar 24, 2015 1:12 am
JohnnyRobot wrote:Bummer... I'm Southeast (Rochester)
It would be 45 minutes to an hour drive from where you are . It's doable . Lol
