Heated Bed Wire Support Bracket
Msculpt
Post by Msculpt » Sun Mar 13, 2016 4:44 am
I was in a state of denial...could it ever happen to me....naaaawww...then my wires broke. I looked back at all the posts I ignored about this when I got my M2 and couldn't really find a solution I liked, so I made one.
http://www.thingiverse.com/thing:1411662
Msculpt
Re: Heated Bed Wire Support Bracket
Post by Msculpt » Thu Apr 14, 2016 11:41 pm
Important: I just realized that if you have a thin glass build surface and happen to have a V4 hotend on a machine without the heater wire support on the build plate, that using this bracket may give you clearance issues and bump against the nuts on the underside of the X axis rail when you set the zstop appropriately. If you are using a thicker build surface like a Mic6 or zebra plate or an E3DV6 this shouldn't be an issue.
