MIC6 preorder number 2 *READY FOR SHIPPING*
crazyg0od33
Re: MIC6 preorder number 2
Post by crazyg0od33 » Wed Aug 24, 2016 11:34 am
alright then I'm good for no blasting. I have no real plans to print in nylon, and if I do I'll just throw the boro back on and readjust my starting height
GuardsmanBlue
Post by GuardsmanBlue » Wed Aug 24, 2016 3:50 pm
I'm in if you still have any available. I have a sandblaster so no blasting necessary on mine if it'll keep the cost down.
Royce_Arnold
Post by Royce_Arnold » Wed Aug 24, 2016 4:26 pm
I'm still in for Qty 2 with PEI. If it will make them easier to make, I'll opt out of the bead blasting for both.
Royce
Re: MIC6 preorder number 2 *LAST CALL*
Post by insta » Sun Aug 28, 2016 8:54 pm
Closes wednesday, ordering everything then. ALL sheets will be PEI preapplied, smooth both sides.
sgrankin
Post by sgrankin » Tue Aug 30, 2016 5:48 pm
Interested in 1 with PEI.
Re: MIC6 preorder number 2 *HERE WE GO*
Post by insta » Sat Sep 03, 2016 1:18 am
Parts en-route.
These will be exactly $99, plus actual S&H (which I think is $13?). Once they're made, I'll post the purchase link.
Technical specifications:
* MIC6 aluminum, 8x10". The parts may be slightly undersized by up to 1/16".
* 1/16" Ultem PEI preapplied with 3M 3535 urethane adhesive, rated to 120C.
* PEI will be scoured slightly. You'll get a tighter bond over time with the matte finish.
stee1hed
Post by stee1hed » Fri Sep 09, 2016 5:20 pm
Subscribing just in case there is an extra one...
Post by insta » Sun Sep 11, 2016 12:33 am
I have all 21 beds and 21 PEI coverings cut out. The polyurethane adhesive I wanted to use isn't going to work out -- so I've now ordered the 3M transfer sheets. Once those arrive I can start shipping.
LonV
Post by LonV » Thu Sep 15, 2016 10:38 pm
I'm interested in one that's smooth on one side and bead blasted on the other (don't care about PEI).
Post by insta » Fri Sep 16, 2016 6:49 pm
LonV wrote:I'm interested in one that's smooth on one side and bead blasted on the other (don't care about PEI).
Well we have an arrangement then -- I have one that's covered in my failed adhesive project. Sanding that off will produce the nice rough edge you want, and save me from trying to use it for the PEI sheet.
Locked
