MIC6 preorder number 2 *READY FOR SHIPPING*
Re: MIC6 preorder number 2 *READY FOR SHIPPING*
Insta,
Thanks so much for these. Mine is working great!
Quick update - the 99% alcohol did the trick! Sticking like the day it came in.
Finally got time to set this up and make a few prints this week. Works great!
A couple things I encountered:
- The surface temperature was about 10C lower than the set point for the heated bed. Turned out my heated bed sags a bit in the center, so I put some thermal paste between the two and the temperature is pretty accurate now.
- Occasionally a small layer of the print gets stuck to the PEI; the first time I saw it I thought I managed to jam the nozzle into the PEI and melt it, but after hitting it with a scraper it turned out to just be leftovers.
- And yea, I turned down the acceleration because my table started shaking a bit more with the heavier plate. (I was still using default).
Otherwise, sticks great and is pretty much indestructible.
Thanks insta!
Thanks insta!
sgrankin wrote:Finally got time to set this up and make a few prints this week. Works great!
Thanks insta!
My bed sags as well, but I have no way of measuring the actual temp - may need to grab an IR thermometer or something to check it
Remember that IR thermometers:crazyg0od33 wrote:grab an IR thermometer
- Assume an "organic" target: you get incorrect results from bare metallic surfaces like aluminum plates. Always apply tape to the metal as a target and verify that "room temperature" readings make sense.
- Report the average temperature of a circle in front of the opening: the laser dot serves as an aiming guide, not a pinpoint target. The circle embiggens with distance: about 1 inch at 6 inches, 2 @ 12, 4 @ 24.
- Can't measure the temperature of anything smaller than that circle at any distance: hot ends and transistors are too small.
Nice usage of "embiggens", my favorite, perfectly cromulent word.ednisley wrote:The circle embiggens with distance: about 1 inch at 6 inches, 2 @ 12, 4 @ 24.crazyg0od33 wrote:grab an IR thermometer
cheers,
c
Will this completely replace boro glass or do you pull it out for specific jobs? I am currently using boro and hairspray which is easier for me than kapton tape.
CCRN wrote:Will this completely replace boro glass or do you pull it out for specific jobs? I am currently using boro and hairspray which is easier for me than kapton tape.
it completely replaced the glass for me
Ordered. Hoping the PEI layer lasts for a long time. How much time can I expect out of the PEI layer and can it be removed and a new sheet reapplied?
If you don't do stupid stuff with it, the PEI should last for a very long time. My first PEI bed got some small nicks in it where I was trying to pull parts off while still warm, and also some from where a razor blade flexed. I haven't added any new nicks for a long time. I recently removed the PEI, cleaned it up with acetone, and will put the sheet back down with the nicked surface down one of these evenings.
