Spider Conversion (from 3 to 4 Point Leveling)
daveb
Re: Spider Conversion (from 3 to 4 Point Leveling)
Post by daveb » Sun Dec 04, 2016 10:45 pm
Couldn't you use blind rivet nuts for this?
Post by sthone » Mon Dec 05, 2016 4:00 pm
daveb wrote:Couldn't you use blind rivet nuts for this?
That's actually a good idea.... I'll have to look into it and see if I can find one that will fit the hole and still have a small enough thread size.
ob1
Post by ob1 » Sun Feb 12, 2017 1:13 am
Here's a 'no spider machining' approach that uses those 6.2 mm diameter holes in the corners of the spider: http://turtlesarehere.com/html/4_point_leveling.html. The design approach is not original. This seems to work well and the bed is certainly more secure than with the 3 point MG system. Although levelling without a Z probe is not as straight forward as the 3 point system, the bed tilt per turn of an adjustment screw is significantly finer.
Post by ednisley » Tue Feb 14, 2017 12:33 am
mookthai2017 wrote:have that dimpled effect
In any other context, you'd be looking at a failed print on the way to the scrap pile. You get that "dimpled" effect from a single top layer collapsed into sparse infill. On the other paw, the post dates from 2011, when anything looked good, particularly from that hardware.
Don't use SketchUp for 3D modeling: life is too short for so much suffering.
ob1
Post by ob1 » Wed Feb 22, 2017 6:16 am
@mookthai
would you please correct the link in your post that is quoted from me. Somehow you have added a "gclub" at the end of my link and this is not what I posted - nor does it direct to my link.
Thanks,
ob1
