'Mammoth' Part Cooler
Posted: Fri Nov 11, 2016 6:46 pm
Hi everyone I'm new to 3D printing, I've been at it for a couple months now and I'm loving my M2. So far I've upgraded it with one of insta's Mic6 plates and that alone had been awesome. Over the past two weeks I've been devising a new design for a blower driven part cooler. After much trial and error I'm ready to present to you my first revision of my new 'mammoth' cooler!
Files for printing:
http://www.thingiverse.com/thing:1886404
Some info:
-- This cooler is printed in 3 parts - main body, tube 1, and tube 2.
-- I used the original makergear fan/hotend connector body to accommodate the main platform for the two 50mm 24v blowers so all credit for that piece goes to makergear. I purchased the 50mm blowers from reprapchampion.com.
-- blowers are wired together and wired into a pigtail cut from the original 50mm cooling fan.
-- I used black hatchbox ABS @ 240c hotend/ 110c build plate, .2mm resolution, .40 extrusion width, .89 extrusion multiplier. (first time ever using ABS, very happy with the result)
-- Printed directly on build plate's PEI surface with no helpers such as glue or slurry. Adhesion was excellent.
--Supports not required on the two tubes if printed with rectangular opening side on build plate, supports are required on the main body.
Pics:
https://flic.kr/p/NYo3SB
https://flic.kr/p/NYo3Sg
https://flic.kr/p/P6NRpi
https://flic.kr/p/NDdbj3
https://flic.kr/p/P6NRkR
https://flic.kr/p/N8BoUk
Files for printing:
Some info:
Pics:
