Printing on Transparent Laserprinter Film
msonst
Post by msonst » Sat Nov 12, 2016 7:02 am
Hi,
I thought I just share my latest experiment with you :-)
As I ran out of Kapton Tape I tried laserprinter transparent color film cut to the size of the platform with bed temp 70°C extruder 215°C.
The film has been cleaned after attaching with 91% isoprophyl alcohol.
For a first test the sheet was not glued to the glas platform.
Could be done with water, glue mixture, pure water (probably) or hairspray I guess.
The test Object was a 10x10x10 cube on a Makergear M2 Rev E.
Filament: Makergear PLA
Setup:
Setup
Here are the results:
Glas platform can stay in place after print and film is detached.
The film can be bended while the cube stays in place (r~1cm):
Bend_Film
After bending further than, that the cube came off easily:
cube_comes_off
Bottom surface quality was ok (smoother than my Kapton prints):
surface
View from below after bending:
bottom
According to some posts online the max temp for monochrome laser film is 190°C, this is why I used color film (220°C).
Quite interesting from my perspective is:
  • Builds can be easily taken off the printer
  • Print sticks very well
  • Possibly the ability to bend the surface afterwards can be used somehow to e.g. print on film and attach to car glas or windows.
Unfortunately I don't have ABS here. It would definately be interesting whether it sticks or not ;-)
Have a great weekend
Michael
Edit: I double-posted this topic accidently. I appologize and delete the other.
Visit me at sonsts.de
