Is there a model available of the extruder?
SLCJedi
Post by SLCJedi » Sat Nov 26, 2016 1:11 am
Hey all, I did some searches, but maybe I don't have the right terms. Does anyone have a model of the entire machine or at least the extruder? I'm trying to design a print fan using a 50mm blower that blows at 270-360 degrees around the nozzle.
Thanks in advance.
Hugs
Re: Is there a model available of the extruder?
Post by Hugs » Sun Nov 27, 2016 12:11 am
The first place I'd check would be the Github repo: https://github.com/MakerGear/M2
SLCJedi
Post by SLCJedi » Sun Nov 27, 2016 2:41 am
I have only found the 3D printed pieces, not the whole extruder assembly on Github. :)
Slipshine
Post by Slipshine » Sun Nov 27, 2016 10:34 pm
It could just be me but if your new to the north there are better ways to warm your room in the winter. ;)
Hugs
Post by Hugs » Sun Nov 27, 2016 10:48 pm
SLCJedi wrote:I have only found the 3D printed pieces, not the whole extruder assembly on Github. :)
Ah...I see. So you want a full 3d model of this entire assembly?
SLCJedi
Post by SLCJedi » Mon Nov 28, 2016 1:02 am
That's it. I have now modeled most of the important bits. So kind of a moot point. :)
SIERRA086
Post by SIERRA086 » Wed Nov 30, 2016 6:00 pm
SLCJedi wrote:That's it. I have now modeled most of the important bits. So kind of a moot point. :)
Would you mind sharing? It would be great to have for a modding reference point.
SLCJedi
Post by SLCJedi » Fri Dec 02, 2016 1:46 am
Sure. I will upload to thingiverse as an STL. I'm using 123D Design, so not many options for files unless you use 123D as well.
Here is what I have as a crazy dual 50mm blower option. Still have to work out the bracketry. I will also make a single 50mm blower version as the dual may be a lot of weight.
SLCJedi
Post by SLCJedi » Fri Dec 02, 2016 2:02 am
Basic model for orientation in SLT and 123dx here:
http://www.thingiverse.com/thing:1932742
SIERRA086
Post by SIERRA086 » Sat Dec 03, 2016 12:23 am
thank you very much for sharing this, should make my future modifications much easier to implement!
