Power Supply Cooling and Fan Replacement
ob1
Post by ob1 » Wed Feb 22, 2017 8:21 am
If you have an original M2 power supply in the laser cut plastic case then chances are it may be running too hot due to inadequate cooling. This reduces the service life of the power supply. You can read about replacing the fan and improving the power supply cooling through appropriate vent sizing and location to minimize cross-flow at: http://turtlesarehere.com/html/power_su ... oling.html.
