Filament Clips
jdacal
Filament Clips
Post by jdacal » Tue Sep 08, 2015 8:31 pm
I got tired of the printed clips deforming and slipping off, sliding around and generally being a nuisance so I switched to these mini clips. They stay on rock solid and you get 60 for less than 3 bucks on Amazon. Plus you can even clip them to the outside of the reel while printing so you don't lose them.
These are the same as the clips used on the bed but "Mini" size. They are much smaller than that picture makes them appear.
http://www.amazon.com/dp/B00006IBA3/ref ... words=clip
2015-09-07 13.49.18_1.jpg (257.67 KiB) Viewed 10686 times
jdacal
Bratag
Re: Filament Clips
Post by Bratag » Tue Sep 08, 2015 8:46 pm
I think sometimes having a 3d printer is a "To a man with a hammer, everything looks like a nail" situation. 3d printed clips seem great in theory but I found the same as you. Over time they slip. This seems like a good solution :)
Re: Filament Clips
Post by Jules » Tue Sep 08, 2015 8:55 pm
Those work very well as bed clips too - just bend them open a little with pliers. (Less chance of hitting the clip with the nozzle on a print that extends towards the front.)
I might need to switch to those for the spools too - i keep stepping on the little printed clips i'm currently using. :D
Rara
Re: Filament Clips
Post by Rara » Wed Oct 14, 2015 2:37 am
Why not just use the holes in the spool? Those are free and will never fall off and get lost. ;)
2012 M2 V4-PTFE
Re: Filament Clips
Post by sthone » Wed Oct 14, 2015 3:19 am
Combine them with a piece of cloth and they double as a filament wiper too.
thunderbt3
Re: Filament Clips
Post by thunderbt3 » Wed Oct 14, 2015 12:48 pm
We have a Zortrax M200 at work. We use these filament clips. It says it works with Zortrax filament rolls only, but I haven't tried on any other rolls.
http://www.thingiverse.com/thing:386570
Matt_Sharkey
Re: Filament Clips
Post by Matt_Sharkey » Wed Oct 14, 2015 10:32 pm
Rara wrote:Why not just use the holes in the spool? Those are free and will never fall off and get lost. ;)
those holes are a PITA, and never at the right spot :P
thunderbt3 wrote:We have a Zortrax M200 at work. We use these filament clips. It says it works with Zortrax filament rolls only, but I haven't tried on any other rolls.
While I'm sure that those clips are great for your purpose, I think what jdacal is getting at is; More people should follow the "KISS" Principle.
https://en.wikipedia.org/wiki/KISS_principle
