Filament suggestions for outdoor use, that doesn't need a heated print enclosure?
Beer
Post by Beer » Sun Aug 21, 2022 5:14 pm
Hi. So far I have only used PLA on my M2. Can anyone recommend a good filament that maintains its strength in high heat outdoors (direct sunlight, hot climate) that doesn't need a heated enclosure to print? I occasionally need to print items intended for outdoor use and it can get extremely hot where I live.
I thought I had my mind made up on Polymax PC or Prusament PC Blend, until I learned that a heated enclosure is more or less necessary for proper layer adhesion and strength. I've also read that PETG is only marginally better at heat resistance than PLA.
I mainly just print little things for around the house, and I don't have a workshop or even a dedicated space for my printer at the moment, so an enclosure is out of the question for the time being. And I don't think Makergear offers a premade kit enclosure or anything either, which is unfortunate.
Something easy to work with like PLA, but with better heat resistance would be ideal. Any suggestions are appreciated. Thanks!
Re: Filament suggestions for outdoor use, that doesn't need a heated print enclosure?
Post by airscapes » Sun Aug 21, 2022 7:11 pm
PETG is much better than PLA for heat and it is a bit more flexible without breaking. I have surveillance camera mounts I designed, which are outside in full sun, east coast summer/winter, going on 4 years now, no issue.
Gwhite
Post by Gwhite » Mon Aug 22, 2022 12:36 pm
PETG is also UV resistant. I've used PETG for some fence brackets, and they've held up just fine.
theboz1419
Post by theboz1419 » Sun Aug 28, 2022 11:55 am
I too recommend PETG. Its all I use, now. Esun works really good. There is a simplify3d file for Esun PETg on the forums I use to print.
Phil
Post by Phil » Wed Aug 31, 2022 4:58 pm
Would you mind giving us the link? I have my own S3D file, but would like to compare. There is a thread here for sharing those files, but it has been so long, I have forgotten. Insta's something-or-other?
theboz1419
Post by theboz1419 » Tue Dec 13, 2022 2:01 am
viewtopic.php?t=2593
Better late then never, lol. Sorry just saw this today..
