Thanks Jim, have you used it before from Ultimachine? Works ok? I'm going to need the big reel for this print I'm doing. Also Makergear shows out of stock at the moment on the small black reels.jimc wrote:Not that i am aware of. Only place i know for sure is ultimachine. You may be able to get them from push plastic as well since they are a manufacturer but you would need to call them.
Brands of filament used successfully in your M2
Re: Brands of filament used successfully in your M2
Push plastic is adding 3kg rolls shortly.jdacal wrote:Do you guys know if Makergear sells the larger reels of filament? I guess the one that weighs about 5 lbs?
