Hello, I am new to the forum and have a question about HatchBox Filament.
What are the Temp. with PLA Heater & Bed ?
Thanks...
HatchBox Filament
3dPrintingMD
Re: HatchBox Filament
Heated bed 55-60.
Extruder - 205 has worked well. What color are you using ?
if you use the wood one u can go a lil down most wood pla like 195-200
for the bed it really depend from the bed type if you talking about glass or pei or tape most probably 55-60
if you talk about Zebra plate i usually print between 37-38
another factor is the room in which u are printing if is conditioned or if there is possible breeze passing near the printer if is cold if is humid...
if is near a windows and outside is cold etcetc i notice it does matter the air around the printer (thats why some printer are close make it easier to eliminate that variable)
