ePC eSun PolyCarbonate settings?
Vandal968
Post by Vandal968 » Mon Jan 18, 2016 12:58 am
I've been unable to find detailed setting recommendations for printing in ePC (eSun PolyCarbonate). I saw that insta recommends 250c, and jimc says 270c for extruder temps. Any other pointers for other settings? Bed temps, speeds, fan?, etc.
thanks,
c
willnewton
Re: ePC eSun PolyCarbonate settings?
Post by willnewton » Mon Jan 18, 2016 1:05 am
viewtopic.php?f=11&t=2592&hilit=Epc+esun
Jim's FFF file on page 2 and mine is on page 3
Vandal968
Post by Vandal968 » Mon Jan 18, 2016 1:11 am
Wow, thanks. Don't know how I missed that.
cheers,
c
Post by insta » Mon Jan 18, 2016 3:32 am
Vandal968 wrote:I've been unable to find detailed setting recommendations for printing in ePC (eSun PolyCarbonate). I saw that insta recommends 250c, and jimc says 270c for extruder temps. Any other pointers for other settings? Bed temps, speeds, fan?, etc.
thanks,
c
I also recommend 270C, FYI. It just works down to 250C.
I use 0.25 layers, 40mm/sec, 270C nozzle, 105C bed, 0.98 multiplier, 1mm retract.
Post by jimc » Mon Jan 18, 2016 3:44 am
yup, i found if its get low down to 250 it will print just fine but you start to have layers that arent bonded great. i use very little coasting 0.2. retraction 1.2. bed temp 100deg. never use the print cooling fan.
bignordique
Post by bignordique » Thu Jan 28, 2016 7:23 pm
Is it possible to print ePC with a V3b extruder?
Desire the flammability rating but don't want to upgrade to V4.
bignordique
Post by insta » Thu Jan 28, 2016 7:39 pm
bignordique wrote:Is it possible to print ePC with a V3b extruder?
bignordique
You might, since you'll need to run at 250C, but that's hotter than the V3b is recommended to run.
bignordique
Post by bignordique » Thu Jan 28, 2016 7:46 pm
insta wrote:You might, since you'll need to run at 250C, but that's hotter than the V3b is recommended to run.
Hmmm.... that's interesting. I've run 10s of KG of PETg through my V3b at 250 with no apparent problems??
Ignorance is bliss apparently.
bignordique
bignordique
Post by bignordique » Thu Jan 28, 2016 7:51 pm
OK next question. Is the V4 upgrade a one way trip?
I've got the V3b dialed in for what I'm doing. Is it possible to easily switch between V3b and V4??
bignordique
Post by Jules » Thu Jan 28, 2016 9:05 pm
One way trip. You change the Z-stop setup. (It's a very good trip though.) :D
If you want to print any filaments with temps over 250 long term, then you need to upgrade to the V4.
The V3b can handle 250, (and 255 for a layer or two), but you wouldn't want to melt the hotend (or your house) at anything higher. :shock:
Joking of course, but heat creep is a real problem, and can wreck the V3b. (And the V4 is so much easier to swap out and set the gap. Totally worth it. :P )
