Filaments in Your Filament
Posted: Mon Mar 27, 2017 8:23 pm
Hello Group-
My prints from the last four spools that I have opened have contained these little jerks (see below). Is this a manufacturing issue or is this on my end? I have run through the filament path and cannot see where it is getting in. I buy from a well recommended source so I am a bit at a loss here. This is PETG by the way. These are narrow enough that they make it all the way to the heater block but large enough to clog the nozzle. I run at 247 Celsius so I should be melting most plastics but this one won't melt.
Anywho. I would appreciate any recommendations from you guys. If this is just how it is then fine, I can deal with that. If this is an error though I would very much like to correct it.
https://ibb.co/nL4Jqa
