Dual Extruder Firmware with VIKI LCD Panel
I have a VIKI LCD panel (same as was sold by MakerGear at one time) and I love having it mostly for monitoring temps while printing from the SD card.
I enabled the VIKI support in the current dual firmware and I updated pins.h to be the same as the working single extruder VIKI firmware. The display works fine, but the buttons aren't being properly read.
I'll play around with it more this weekend, but before possibly reinventing the wheel, has anyone else modified the dual extruder firmware to enable the VIKI/MakerGear LCD?
Re: Dual Extruder Firmware with VIKI LCD Panel
Any Luck, I will be having the same issue.
I have a hacked-up version of the MG firmware with Viki support and dual-extrusion attached. It does NOT have the skipping problems I talked about earlier. It's been reliable for me but it should be noted this is an experimental version, not supported by MG, etc etc.fmeroney wrote:Any Luck, I will be having the same issue.
If you get errors about missing LiquidTWI2, move the two files from the root folder into the Marlin folder and relaunch the Arduino IDE before building.
- M2_LCD_Firmware_24Vw24Vheater_-_Dual-2015-04-06.zip
- (2.87 MiB) Downloaded 808 times
Fantastic, i will be purchasing the dual extruders... In gerneral are they worth it? Do you have any pictures?
Thank for the quick reply!
insta wrote:I have a hacked-up version of the MG firmware with Viki support and dual-extrusion attached. It does NOT have the skipping problems I talked about earlier. It's been reliable for me but it should be noted this is an experimental version, not supported by MG, etc etc.fmeroney wrote:Any Luck, I will be having the same issue.
[quote="fmeroney"]Fantastic, i will be purchasing the dual extruders... In gerneral are they worth it? Do you have any pictures?
Check the other threads in the Dual Extruder forum. Both questions answered and more
Have you made any changes to the experimental version of the firmware or will MG send the firmware updates with the dual upgrade?insta wrote:I have a hacked-up version of the MG firmware with Viki support and dual-extrusion attached. It does NOT have the skipping problems I talked about earlier. It's been reliable for me but it should be noted this is an experimental version, not supported by MG, etc etc.fmeroney wrote:Any Luck, I will be having the same issue.
-Don
Eh, just "comfort" changes. The homing speeds are a bit higher, the accel and jerk are a bit lower. MG does not send firmware with the dual-extruder update, at least they didn't when I ordered mine.dsmith wrote:Have you made any changes to the experimental version of the firmware or will MG send the firmware updates with the dual upgrade?insta wrote:I have a hacked-up version of the MG firmware with Viki support and dual-extrusion attached. It does NOT have the skipping problems I talked about earlier. It's been reliable for me but it should be noted this is an experimental version, not supported by MG, etc etc.fmeroney wrote:Any Luck, I will be having the same issue.
-Don
Firmware without vikijsc wrote:What's this, then: http://makergear.wikidot.com/dual#toc1
Insta,
I installed the firmware and my screen looks like this picture in simplify3D... Any ideas?
-Don
-Don
