Wiper
Rocketdog
Re: Wiper
Post by Rocketdog » Sat Aug 09, 2014 2:04 am
My 2nd extruder ran backwards and it turned out that reversed the harness' in the wire cover. It became evident when the first print had tool paths 62 mm apart on the bed. They are now on top of each other
Rocketdog
Re: Wiper
Post by Rocketdog » Sat Aug 09, 2014 10:47 pm
Here is an example of a Cura ooze shield and prime tower. I had to use a brim to keep the tower from getting knocked over. There is a robot in there somewhere
Rocketdog
Re: Wiper
Post by Rocketdog » Sat Aug 09, 2014 10:52 pm
(829.46 KiB) Downloaded 383 times
Josh
Site Admin
Re: Wiper
Post by Josh » Tue Aug 12, 2014 8:59 pm
Dale, the only difference between the dual .factory file posted on the wiki, and that print you saw, was the extrusion multiplier - the .factory is set to 0.90 (standard PLA), while the print I was running on Friday was at 0.87 for both nozzles, both processes.
