Page 1 of 2
Dual extruder parts
Posted: Thu Aug 07, 2014 11:06 pm
by Rocketdog
It's not much but it's a start
Re: Dual extruder parts
Posted: Sat Aug 09, 2014 1:28 am
by Dale Reed
So, for your O-gauge train set, you're doing the scenery to be "Cleveland in Summer", huh? You're gonna need a few hundred of those!
Very nice!
Posted: Sun Aug 10, 2014 7:52 pm
by markb
Rocketdog wrote:It's not much but it's a start
Alright your cone looks really good. I just printed one and it looks very bad what settings did you use?
I have a big stringing pile on the left and right of my cone.
Posted: Sun Aug 10, 2014 11:53 pm
by Rocketdog
If you used S3d, did you do the shift/ align object command to put both models over each other? Have you printed anything that worked to verify the head offset?
Posted: Mon Aug 11, 2014 4:27 am
by Rocketdog
Used Cura ooze wall
Posted: Tue Aug 12, 2014 1:20 am
by markb
Rocketdog wrote:If you used S3d, did you do the shift/ align object command to put both models over each other? Have you printed anything that worked to verify the head offset?
Yes I did the shift align and that worked fine.
I have not verified the head offset yet.
Posted: Tue Aug 12, 2014 2:35 am
by Rocketdog
Did it print the cone and two piles or just two piles
Posted: Tue Aug 12, 2014 2:59 am
by markb
Yes the cone printed. The piles on the right and left were like artifacts that maybe retraction could solve.
I thought maybe you had setup some retraction.
Posted: Tue Aug 12, 2014 4:53 am
by Rocketdog
I used the retract code that's on the makergear dual wiki in the slicing paragraph. Just put the code in the scripts tab in S3d.
Posted: Sat Aug 16, 2014 2:40 pm
by Rocketdog
I think I need a litte more retraction and a little less extrusion
