Dual extruder
Tshulthise
Re: Dual extruder
Post by Tshulthise » Mon Apr 14, 2014 10:18 pm
I owned a CubeX Duo for a while that had dual extruders. The trick seemed to be to make sure each hot end primed itself before each time it engaged the print. They had a rectangular box with a teflon wiper that the extruders would go to and spit out some filament before engaging the print. The Teflon wiper allowed the string to be wiped off similar to how the M2 does before starting a print.
Something they didn't do very well was make it easy to get the extruder tips at the same height. All you need is to mount the hot end in a cylindrical "hole". If you can raise the bed to touch the nozzles while they are loose then tighten both hot ends without affecting their z-offset then its easy and they will be nearly perfect.
Of course, that process throws the z offset off so it would be nice to have an auto z offset referenced to one of the hot ends so its not affected by hot end z position changes. I haven't seen anyone do that yet but I don't know why. Its not very hard to conceive how to do it relatively simply.
Zeeflyboy
Re: Dual extruder
Post by Zeeflyboy » Thu Apr 17, 2014 3:33 pm
That looks extremely compact... I liked the look of the v4 hot end too so it's all win really!
Hopefully I can buy one soon?!! Please?!
KeithA
Re: Dual extruder
Post by KeithA » Tue May 27, 2014 3:14 am
Any update as to when this dual extruder (V4) is projected to be available?
Capt. John
Re: Dual extruder
Post by Capt. John » Fri May 30, 2014 6:29 am
Where's the second spool of filament going to be located?
Capt. John
Manistee, Michigan
Reel Amateur at 3D printing
http://www.michiganangler.com
rpollack
Re: Dual extruder
Post by rpollack » Fri May 30, 2014 2:36 pm
Sorry for the delay in posting here. We will be making the dual-extruder announcement in a matter of days...probably not today as I am still waiting on some info...but very soon. The hot-end is all metal and part of the mount is machined so there may be some sticker shock.
Thank you for your patience,
Rick
markb
Re: Dual extruder
Post by markb » Tue Jun 03, 2014 4:31 pm
rpollack wrote:Sorry for the delay in posting here. We will be making the dual-extruder announcement in a matter of days...probably not today as I am still waiting on some info...but very soon. The hot-end is all metal and part of the mount is machined so there may be some sticker shock.
Rick
This is great news (except for the sticker shock :D )
sprior
Re: Dual extruder
Post by sprior » Tue Jun 03, 2014 10:15 pm
So, how do you make a bunch of geeks hold their breath....
Re: Dual extruder
Post by jimc » Wed Jun 04, 2014 2:09 am
sprior wrote:So, how do you make a bunch of geeks hold their breath....
haha :lol:
sprior
Re: Dual extruder
Post by sprior » Fri Jun 06, 2014 6:37 pm
Turning all shade of blue over here - Rick, can you help us out?
Capt. John
Re: Dual extruder
Post by Capt. John » Wed Jun 18, 2014 5:28 am
Will the main advantage to this being able to use water based filament for supports that can be washed off the models?
Capt. John
Manistee, Michigan
