Has anyone come up with a dial indicator mount for the dual?
LazMech
Re: Has anyone come up with a dial indicator mount for the d
Post by LazMech » Fri Jul 10, 2015 2:55 am
http://www.thingiverse.com/thing:918939
I haven't leveled my bed with it yet but should work and should allow the probe to touch the entire bed surface. Just don't print with the dial indicator mounted obviously. When you print this part make sure you re-orient it so that the fan mounting surface is face down on the bed and add supports (I used the ones Simplify3D automatically generated, they worked fine). I bought some extensions so that I can probe at different bed heights to make sure the bed is level at different heights.
sprior
Post by sprior » Fri Jul 10, 2015 3:51 am
Thanks for making that, will have to try it.
