Dual Extruder Upgrade
nirfriedman
Post by nirfriedman » Tue Aug 25, 2015 1:20 am
Hi All,
I recently bought an M2 (V4 single extruder) and also the dual extruder upgrade kit. I would appreciate some comments/recommendations from people who gone through the process. How long did it take to install the kit? how much pain was it to get things working again afterwards? Any suggestion beyond the assembly instructions provided with the kit?
Nir
sckibbons
Re: Dual Extruder Upgrade
Post by sckibbons » Mon Aug 31, 2015 2:55 am
It took me a few hours. Just take your time and read the directions carefully. After you get the hardware all set up, make sure to check out the wiki link below. This should help you get setup.
http://makergear.wikidot.com/dual
nirfriedman
Post by nirfriedman » Mon Aug 31, 2015 3:31 am
sckibbons wrote:It took me a few hours. Just take your time and read the directions carefully. After you get the hardware all set up, make sure to check out the wiki link below. This should help you get setup.
Thanks! this will wait for next weekend I guess.
nirfriedman
Post by nirfriedman » Mon Sep 07, 2015 5:59 pm
ok. so I went through the assembly instructions, and I have minor comments that I will send MakerGear support (mostly that pictures of black parts and black wires against black background are not that informative...)
Now I understand (from the wiki, not from anywhere else) that I need to upgrade the firmware. Is the recommendation to stick to Arduino 1.5.5 is still relevant or are the new versions stable?
Before I realized that I wanted to test the extruder. I managed to see that the tension of the extruder filament guide was totally off, and was happy to find a thread here that explains how to tune it (would have been nice to get that as part of the instructions).
However, it seems that the filamenet is not getting into the hotend. As far as I can tell I don't have any play in aligning the guide to the hotend when I install it. Any way of checking that???
What checklist of other stuff I need to go through, such as checking that the wiring is correct and so on?
nirfriedman
Post by nirfriedman » Tue Sep 08, 2015 1:26 am
nirfriedman wrote: However, it seems that the filament is not getting into the hotend. As far as I can tell I don't have any play in aligning the guide to the hotend when I install it. Any way of checking that???
With a quick reply from the (amazingly responsive) MakerGear support, I found out that you can tune the angle of the filament guide. removed the fan, untightened the two screws that hold the guide, and then carefully extruded filament and guided it to the right position. I then extruded about 100mm. At this stage the filament was holding well at the guide and in the hotend. This helped maintain the position when I tightened the screws back on. Now it works nicely.
Post by jsc » Tue Sep 08, 2015 2:11 am
While you probably should use the supplied dual extruder firmware uploaded with 1.5.5, I recently put together a version of the latest released Marlin (1.0.2) that you might consider trying if you want to live on the edge: viewtopic.php?f=9&t=2708
It turns on/off the extruder fan at 50C, and includes a workaround for the missed steps issue, so you can use 1.6+ to upload it.
nirfriedman
Post by nirfriedman » Tue Sep 08, 2015 7:24 pm
jsc wrote:While you probably should use the supplied dual extruder firmware uploaded with 1.5.5, I recently put together a version of the latest released Marlin (1.0.2) that you might consider trying if you want to live on the edge: viewtopic.php?f=9&t=2708
Thanks! Getting the thing to print properly is sufficient challenging right now, so I will stay with the stable version. Looking forward to upgrade when the new one is less of "living on the edge"
