The instructions that MakerGear has posted for the dual extruder mention the use of the special substitution syntax:
Code: Select all
T[old_tool]
T[new_tool]
Now, the simple and obvious solution which the Simplify3D developers apparently didn't think of is to have two separate tool change scripts. But they did hack in a solution that, ugly as it is, works, and is better than using old_tool, new_tool. That syntax looks like (for example):
Code: Select all
{IF NEWTOOL=1} G1 X20 ; gcode following if statement are executed conditionally
{IF NEWTOOL=0} G1 X100 ; likewise
Note that the MakerGear instructions for the dual extruder indicate that changing temperature of an extruder during a tool switch requires saving the gcode generated by Simplify3D and then editing it (preferably with an automatic script). This {IF} statement feature avoids all that; it becomes possible to write a script that changes the temperature on the two extruders independently, and that is inserted automatically into the gcode.
Here's the pointer to the Simplify3D feature description:
https://forum.simplify3d.com/viewtopic.php?f=8&t=1959
And here is the pointer to the MakerGear description of the awkward tool change hack:
http://makergear.wikidot.com/dual (look at the section "Slicing").
