REV E Dual with LCD Display
peb31976
Post by peb31976 » Wed Apr 06, 2016 1:39 am
I purchased the M2 couple weeks ago with the LCD and dual extruder. Every time I follow the instructions to install new firmware for REV E with black motors the LCD screen doesn't work stays blank and when I use Simplified 3d to try home machine Z axis goes up instead of down to the Home switch. Any suggestions? :( frustrated HELP please :oops:
Re: REV E Dual with LCD Display
Post by jsc » Wed Apr 06, 2016 8:31 pm
You have picked the wrong firmware. You shouldn't have to reflash the firmware on a new machine anyway, but since you have, you should probably contact support@makergear.com to get a pointer to the correct version for your machine.
Post by Jules » Wed Apr 06, 2016 8:53 pm
Oooops, Jin's right....for the dual Rev. E you need to use the ones outlined in the new Installation instructions for the Rev. E Duals:
Download the zip file for the M2 Dual Extruder Firmware here:
http://makergear.wikidot.com/m2-firmware
For the M2 Rev. E Dual choose:
M2E-Production-SnNRd-V100.zip
http://makergear.wdfiles.com/local--fil ... d-V100.zip
Do you need a copy of the revised installation instructions? (You probably ordered and received your printer before they were ready.) If you do, send me a private message with your email address......the PMs don't allow attachments.
And if you have not done so yet....Read the new Beginner's Guide here: (There is a section describing the Dual in it.)
viewtopic.php?f=3&t=3542
peb31976
Post by peb31976 » Wed Apr 06, 2016 9:13 pm
I got correct firmware finally. reason I had to install is because duel is not shipped installed. Then they had revved m2 and I got old firmware. all good now THX
peb31976
Post by peb31976 » Thu Apr 07, 2016 9:18 pm
Here is Correct one for Rev E Black Motor and LCD
http://makergear.wikidot.com/local--fil ... 20Dual.zip
Post by Jules » Thu Apr 07, 2016 9:42 pm
peb31976 wrote:Here is Correct one for Rev E Black Motor and LCD
Where'd you find that one? Has josh got it posted on the Wiki somewhere yet?
