After a year of debating I finally upgraded my M2. Everything went smooth and I have set the z distance and leveled the bed. I printed the the calibration stl and noticed when x homed it was off the plate. I also notice both extruders were heating up. Ultimately it printed and measured out near perfect. The first question I have is what setting do I need to adjust so that when x homes it is on the table or does it not matter? Also I would like to try a simple 2 color model to see how well it works. Does anyone have a suggestion?
Thanks
Upgrade
Re: Upgrade
The X is supposed to home just off the bed on your model of the Dual. And as far as dual color prints - most people head to Thingiverse - there are several there.
CocoNut's Dual Extruder Traffic Cone: http://www.thingiverse.com/thing:21773
Re: Upgrade
Next issue....
The display grid in Simplify3D is smaller than the build plate. I figured this is due to the the reduced travel distance of Tool 1. When I goto print something that goes to the edges of the grid to check level it ends up printing off of the table. I am using the default profile from Simplify3D Dual. Any ideas?
Thanks
Thanks
Re: Upgrade
That's discussed in item 2. here:
viewtopic.php?f=13&t=2984
You can offset it, so that it actually centers the print when it prints, but it's going to appear to hang off the plate in the preview. (It's a bug in S3D.)
