Installing software on Upgraded Dual Extruder M2
Explorer71
I have a MakerGear M2 that I've been very pleased with. A few months ago I bought the dual extruder upgrade. The hardware installation was difficult because the instructions were confusing, but I think I got that finally. Then came the software and I'm lost. I gave up and the printer has sat there while I worked on renovating my house. Now I'm ready to get the printer working (just ordered a GeckoTek plate so solve adhesion problems). I still can't figure out how to change the software in the printer. It doesn't show up when I plug it to my laptop and I'm not a UNIX person. Is there a simple step by step set of instructions on how to change the Arduino and Merlin software for the dual extruder M2?
Re: Installing software on Upgraded Dual Extruder M2
Yes, if you will send me a private message with your email address i can send you a copy. (PM's don't allow attachments.)
Is there a link where I can find the instructions for installing the software as I upgraded to the dual Extruder M2.
They keep the instructions for that updated on the Wiki:
http://makergear.wikidot.com/dualhttp:/ ... 2-firmware
Hate to admit it, but I am stuck here as well at how do I flash the firmware. The link upthread does not work, and I cant for the life of me find anthing on how to flash firmware.
Can someone point me in the correct direction?
Please read the Firmware Installation instructions carefully! You have to get the correct version of Arduino. V1.5.5
http://makergear.wikidot.com/m2-firmware
Ok, had some time today and got through the firmware install, as well as leveling out the new mic6 plate with quick start. Just printed my bracelet to test things and all is well so far.
I now need to get S3d set up and do all the alignment stuff. I have not leveled the second extruder yet as I wanted to make sure it was above the first just to try my firmware.
Think...Think, I have this all working now. I downloaded the two models off wiki, used the dual extrusion wizard in s3d, played with the settings to get the temps to where maker gear seems to use (70c bed and 220 on pla) added a brim or skirt or whatever that little two line outline thing is and pressed go. its about halfway through and seems to not need any offset adjustment. Maybe I will see something that does need it when I take it off the printer, but so far so good.
Chuckle! Great! Don't jinx it!
well final update
Printed.
Was pretty darn close on a side about 25mm
was about 79.5 tall so lost something there
First layer was squished so the bottom measured more than the middle and top. I need to adjust that somehow.
Little ooze on the print at one corner (used black and yellow with black being the small square and the yellow being the L) I had black ooze on one corner of the yellow. Not sure why that is.
Printed.
