Squeal at end of print.
Posted: Tue Aug 13, 2019 8:05 pm
by DonGar
I have an M2 Dual which has been performing flawlessly, except for a loud squeal during a rapid vertical change, usually at the end of each print. I would say that it's a lubrication problem, but I can't figure out what I'm doing wrong.
3-in-1 oil wiped on to the vertical bars with a paper towel (both above and below the printing platform, with the platform run up and down immediately afterwards, and a touch of lithium grease on the vertical screw, both above and below.
Does anyone have any advice?
Re: Squeal at end of print.
Posted: Fri Sep 06, 2019 9:14 pm
by Phil
I had a similar problem; the know on the Z-axis rod was pinched by the wire housing on the extruder assembly.
