Just print right away and mix half playground sand (right term I hope) and the other half plaster of paris. Mix it with water and remove all the bubbles. Then you submerge the print with this mix and let it rest a couple of hours.
Use a fornance to burn away the plastic at 650°C/1200F and clean the mould with compressed air. You got your fire-proof mould and the PLA is completly gone.
Metal is melted in a crucible in a furnace, then poured carefully into the mould. The shell is placed into a sandbed for isolation.
Sounds easy but it takes many hours of testing and rethinking. Lots of failures.
Metal Casting
Kulturfolger
Re: Metal Casting
- Mark the Greater
Re: Metal Casting
I plan to order this guy tomorrow: http://www.gesswein.com/p-10845-paragon ... =&perpage=.
I'll let you folks know what happens when I give it a try...
Love Always,
MtG
MtG
Re: Metal Casting
Or you could just print the whole mold out of sand
- S-Max-sand-3D-printer-ExOne-3dealise.png (491.51 KiB) Viewed 14937 times
- Mark the Greater
