Page 1 of 5
Crack CNC Mill
Posted: Mon Aug 17, 2015 8:34 pm
by Mark the Greater
Hello. I have an odd question:
Given that the M2 is the reverse of a mill, what would happen if you replaced the hot end with a spindle? I would imagine that you would have to reverse your Z axis and model the negative space instead of the object you want, but I'd bet you could run S3D or whatever still.
Anyone tried this? Just spitballing here. Don't mind me.
Re: Crack CNC Mill
Posted: Mon Aug 17, 2015 8:43 pm
by Matt_Sharkey
without ever using S3D, I'd suspect that software wouldn't do it. But there is software out there to write similar gcode for CNC machines that are exactly what you're talking about. the main problem that I see with using the M2 for CNC;
1 replace the bed and spider with a mechanism that holds your material
2 the z axis would be used 100,000 time more because cnc's tend to move the piece around a lot to navigate the bit.
Someone around here just posted a plan from Thingiverse for a cheap CNC machine that's mostly 3D printed. you may want to give it a look if you actually want a CNC at home. otherwise, Keep dreaming :p
Re: Crack CNC Mill
Posted: Mon Aug 17, 2015 8:50 pm
by Mark the Greater
Sounds about right. I just assume that everyone on here had this idea at one point or another. Especially given how prone to pushing limits and modifying everything you all seem to be...
Re: Crack CNC Mill
Posted: Mon Aug 17, 2015 9:02 pm
by Matt_Sharkey
Hows this for pushing the limits.
https://youtu.be/s9IdZ2pI5dA
Re: Crack CNC Mill
Posted: Mon Aug 17, 2015 9:17 pm
Wowsers! Fascinating! (Next toy?)
Re: Crack CNC Mill
Posted: Mon Aug 17, 2015 9:19 pm
by Mark the Greater
Buy me one?
Re: Crack CNC Mill
Posted: Mon Aug 17, 2015 9:33 pm
Mark the Greater wrote:Buy me one?
I'll put your name right under mine on the list!
Re: Crack CNC Mill
Posted: Mon Aug 17, 2015 9:37 pm
by ednisley
Mark the Greater wrote:what would happen if you replaced the hot end with a spindle?
One word: swarf.
- Rough milling an aluminum plate
- Rough Milling.jpg (231.59 KiB) Viewed 26646 times
Also: coolant spray.
You must figure out a way to clamp the workpiece to the Z stage, then beef up the Z-axis motor to apply enough upward force to drive cutters into it. Plastic maybe, wax for sure, metals not so much.
Belt drives aren't intended to withstand cutting forces, so the surface finish would be somewhere on the bad side of awful: there's a reason CNC machines use leadscrews on all axes.
You'd discover why CNC commands originally used "mm/minute" (well, actually they started with "inch/minute") rather than "mm/second".
Aaaaaand Marlin doesn't implement many of the G-Code commands used by subtractive machine tools. Worse, it implements some vital commands
completely differently, for no good reason that I can find.
Back in the day, Makerbot's Cupcake / Thing-o-Matic firmware actually had a CNC mode, because they thought that would be useful. It wasn't.
I loves me some Sherline milling action, but ... it ain't a 3D printer, either.
Re: Crack CNC Mill
Posted: Mon Aug 17, 2015 10:07 pm
ednisley wrote:Mark the Greater wrote:what would happen if you replaced the hot end with a spindle?
One word: swarf.
Jeez, I have to keep looking up the freaking words........way to make me feel like an idiot, ed!
Re: Crack CNC Mill
Posted: Tue Aug 18, 2015 12:04 am
by ednisley
Jules wrote:looking up the freaking words
But it's a
great word, isn't it? [evil grin]
