I'd like to scan motorcycles to eventually make into gifts for their riders.
I'm thinking the Windows Kinect might be the budget method to do this well, thoughts?
3d scanning a motorcycle
RepRap -Prusa Mendel- by Makergear
With Arduino Mega 2560, RAMPS 1.2, arcol.hu hotend.
Re: 3d scanning a motorcycle
You could try something like Autodesk memento, seems to be reasonable.WarMace wrote:I'd like to scan motorcycles to eventually make into gifts for their riders.
https://memento.autodesk.com/projects/ducati-bike
[quote="WarMace"the Windows Kinect might be the budget method to do this well[/quote]
"Do this poorly" might be more accurate: the Kinect has terrible spatial resolution.
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3304120/
Judging from the plot for a door in Figure 11, you should expect ±40 mm distance errors at 3 m: probably not good enough to capture the details that distinguish one motorcycle from another...
Thanks. It seems using software to make a mesh from a lot of photographs seems to be the popular route, I was hoping there was something better than just a regular camera without spending more than the cost of a fancy printer.
According to the paper Ednisley linked, the Kinect is ideal at 1-3 meters and anything after that and accuracy drops off a lot.
you might want to try this with a kinect camera
http://reconstructme.net/
instead if using a static position for the kinect camera, it takes many samples from multiple angles and makes a compost.
cheap and effective.
link showing this in action
http://reconstructme.net/reconstructme-ui/
sample of what cna be accomplished
http://reconstructme.net/3d-model-viewe ... autoplay=0
