Led lights
Pekish79
Led lights
Post by Pekish79 » Fri Dec 18, 2015 9:41 pm
I have been trying to lit my new model with some tiny battery powered led lights
so far in my research
http://www.extremeglow.com/store/p/27-F ... -Pack.aspx
i removed the mirror paper and bent it like in the picture now is 3/4" x 7/8" x more or less 2/5 thick
anyone has used anything smaller
in the same place they sell the (1/2" round x1/2" thick)
http://www.extremeglow.com/store/p/32-B ... ights.aspx
unfortunately they only blink i need steady light
Re: Led lights
Post by Tim » Fri Dec 18, 2015 11:28 pm
LED tea lights come to mind as being what I've seen other people use on projects, but you appear to have already found a solution that is much smaller than that.
Once long ago I used to use grain-of-rice bulbs for lighted model projects, but the LEDs, even if they are a bit bigger, are oh-so-much more convenient with their built-in batteries. Still, your size is always going to be limited by the battery if you do it that way. As long as you can tolerate wiring, it can be as small as you need. . .
Pekish79
Re: Led lights
Post by Pekish79 » Sat Dec 19, 2015 12:36 am
yeah u was trying to avoid the wiring thing this is a quick model solution for competition it wont last long and is not made to be given to the client so I don't want to make a system that will stay there but something i can put in there and remove to use it on next project
but i appreciate the advice ^_^ the more way i learn the better
Re: Led lights
Post by Jules » Sat Dec 19, 2015 1:20 am
There are balloon lights that are smaller than the LED tea lights, but they look larger than what you are using there:
http://www.amazon.com/gp/product/B00JSH ... 1_3&sr=8-3
Pekish79
Re: Led lights
Post by Pekish79 » Sat Dec 19, 2015 1:53 am
they would look good in some sci-fi model ehehe
vesteroid
Re: Led lights
Post by vesteroid » Wed Jan 04, 2017 11:32 pm
This kit shows what I would think would work.
I dont have one at my desk, but I bet they are about .200" across?
I know thats a kit but shows what led I was thinking of. I just did a search on bread board led and found that
https://www.amazon.com/Elegoo-EL-CK-002 ... breadboard
