<t>I've been printing a ton of stuff on my new machine... Yesterday, I was getting failed prints and saw that the probe was bent. When a print starts, the head will travel to the far right and bump into the other head... It has been doing this all along, but not causing any problems. Now its not calibrating properly. I can bend the little plastic probe back, but its still not leveling properly. I plan to re-install this weekend to see if that will solve the problem, but my question.... Why is the left head going all the way into the right head and stalling??? it makes a bad sound like the belts are skipping the teeth on the gears, then goes back to normal.<br/>
<br/>
Thanks, Mike</t>
Probe is getting bent
Re: Probe is getting bent
Should this be in the M3-ID thread?
oops... thanks for catching
