2nd Extruder z-height calibration
I cannot seem to find documentation that explains how to calibrate the Tool 1 z axis. When I try to dual print, the right (Tool 1) is too high, and will not print properly (blobs up on head instead of adhering to surface). I assume a mechanical calibration is required, but would like to use a proven method vs doing this manually and risking to crack my print plate or damage the hot end.
Re: 2nd Extruder z-height calibration
I think it's built into the octoprint makergear setup:
That said, I'd recommend asking support for written instructions, too.
