I found my bed was always high in the middle and it turns out it was a bent X axis frame, low in the middle by 0.1mm.
I bought round shims from McMaster Carr and put them under the rail which fixed the issue.
Time for a new sheet of glass? Which thickness?
mathisyourfriend
Re: Time for a new sheet of glass? Which thickness?
Tolerances on glass aren't that tight. I have 3 glass plates all purchased around the same time. One of them needs a small Z-offset. Some variation is to be expected.
Thanks. Rechecked the glass and it's also much less than flat. Somehow had it "tuned" with old the M2. Ordering another plate.
mathisyourfriend
Bought a new plate from Makergear. Works great.
