Page 3 of 3
Re: Printing with my new spool holder.
Posted: Fri Oct 31, 2014 6:01 am
by jdacal
Ok, I have good news and bad news. It seems to be working great! The bad news is you can't use the original spool holder with the mount as I modified it, so if you want to use it you'd have to print both pieces. Also the nylon washers I used are optional I included to reduce wear from the parts rubbing against each other.
It was made per creative commons license based on this design:
http://www.thingiverse.com/thing:119488
This is the link to the REMIX:
http://www.thingiverse.com/thing:523415
![IMG_6851_1.jpg](./download/file.php?id=717&sid=539eab66cb97946defa77133129cbb1d)
- IMG_6851_1.jpg (97.93 KiB) Viewed 11391 times
![IMG_6876_1.jpg](./download/file.php?id=715&sid=539eab66cb97946defa77133129cbb1d)
- IMG_6876_1.jpg (156.28 KiB) Viewed 11391 times
![IMG_6877_1.jpg](./download/file.php?id=718&sid=539eab66cb97946defa77133129cbb1d)
- IMG_6877_1.jpg (176.93 KiB) Viewed 11391 times
![IMG_6878_1.jpg](./download/file.php?id=719&sid=539eab66cb97946defa77133129cbb1d)
- IMG_6878_1.jpg (165.91 KiB) Viewed 11391 times
Posted: Mon Nov 03, 2014 2:35 pm
by markb
I just got back from a short vacation. I will be printing this up this week.
Thanks for posting it.
Mark
Posted: Wed Nov 05, 2014 6:44 pm
by markb
Your remake is famous
http://pushplastic.com/collections/3-kg ... c3c2fbdf18
jdacal wrote:Ok, I have good news and bad news. It seems to be working great! The bad news is you can't use the original spool holder with the mount as I modified it, so if you want to use it you'd have to print both pieces. Also the nylon washers I used are optional I included to reduce wear from the parts rubbing against each other.
Posted: Wed Nov 05, 2014 7:03 pm
by jdacal
LOL! Thanks Mark
Edit: Wow that's a pretty heavy reel, 6.6 lb. Might have to load test this thing.
Posted: Sun Nov 09, 2014 3:01 am
by jdacal
Hey Markb, if you haven't printed it yet, might want to hold off on it. I'm making a change to it so that it can take some spool adapters I'm re-mixing. I'm going to have to add a groove to it.
Posted: Sun Nov 09, 2014 3:46 am
by markb
I was going to print it tomorrow but I will hold off for the new changes.
Posted: Sun Nov 09, 2014 3:47 am
by jdacal
I'll probably post the updates tomorrow. I'm printing it now, just waiting to confirm everything fits together ok.
Posted: Mon Nov 10, 2014 12:47 am
by jdacal
Posted: Tue Mar 03, 2015 8:22 am
by jdacal
I added this new adapter for the spool holder to Thingiverse today:
http://www.thingiverse.com/thing:706365
![Taulman Adapter.jpg](./download/file.php?id=1352&sid=539eab66cb97946defa77133129cbb1d)
- This is an adapter for the Taulman3D Spools. Lets you use the spool without having to remove the large spool adapter.
- Taulman Adapter.jpg (59.7 KiB) Viewed 11031 times
