type of oil to lubricate rails in m2
jccdesign
Post by jccdesign » Tue Sep 16, 2014 4:38 am
Hi, i would like to know any recommendations for any type of oil used for lubricating rails and metal parts in the m2.
ErikAkia
Re: type of oil to lubricate rails in m2
Post by ErikAkia » Tue Sep 16, 2014 5:06 am
I think the recommendation was for some light grease like lithium grease for the rails and some 3-in-one type oil for the threads on the screw.
Mine came with a small tub of grease and I have not used it up yet. That was a long time ago so I am not sure what they send now.
jdacal
Post by jdacal » Tue Sep 16, 2014 6:26 am
The regular 3 in 1 oil makes me sneeze too much. So I've been trying this stuff. Seems to be working ok and comes with a nice syringe to get it in the rail groove. It's one of those syringes with an o-ring that you just twist the tip to turn off the flow. Can't really give a definite recommendation yet as I haven't been using it very long on the printer. Its worked great in other applications though:
http://www.bocabearings.com/bearing-inv ... tning-lube
For the Z rod I ordered a small tube of lithium grease from Amazon.
jdacal
Post by jsc » Tue Sep 16, 2014 8:03 pm
MakerGear recommends oiling the round rods with 3-in-1 or similar, for rust protection, and greasing the linear rails and threaded rod with lithium grease. You should have received a small pot of it with your printer, and more can be had from any hardware store.
imsmooth
Post by imsmooth » Tue Sep 16, 2014 8:29 pm
I went to an auto store (NAPA) and got a whole tube of lithium grease.
jccdesign
Post by jccdesign » Wed Sep 17, 2014 6:47 pm
Thanks everyone , ill order some 3in 1 .
Lateralg
Post by Lateralg » Tue Sep 23, 2014 7:01 pm
Engine oil is made to very high standards for film strength, lubricity, corrosion resistance. Harmless to ABS, has little/no "nasty" ingredients, and is probably the lowest cost.
Gary
Make Better Things
Make Things Better
Post by jimc » Wed Sep 24, 2014 2:40 am
funny, i use bar and chain oil for my chainsaw. its 30wt and a little more sticky than regular oil so it stays on the rail. i keep it in a small 2oz needle applicator bottle. makes it easy to apply to the groove on the rail
HadMatter
Post by HadMatter » Fri Oct 10, 2014 6:22 pm
I used to played trombone for 3 years, I would Imagine the Slide Oil or Slide Cream Would be hard to beat. Caution Trombone Tuning Slide Grease Is Not the same thing im referring to. It is for a seperate part of the instrument, and is nothing more than Petroleum jelly.
Also having owned A nice fusbol table for years my father, brother, and I Discovered That Pledge Furniture Polish is almost unmatched For the Cleaning and lubrication of the Player Poles. All Pledge will work well But we found the best Results in the Pledge Orange Wipes.
Hatter
HadMatter
Post by HadMatter » Wed Nov 05, 2014 10:11 pm
Local Music shops or amazon, Trombone Slide Cream. its the way to go.
