Will Makergear ever fix the pinion problem?
Posted: Sun Mar 29, 2015 12:27 am
by helix_3
I have officially lost my 6th (!!) stepper motor to a shredded pinion
http://i.imgur.com/3T5oW6K.png. I print pretty much 24/7, so the shredding pinions lead to a broken printer every 2-3 months.
Is makergear ever going to resolve this issue?
Re: Will Makergear ever fix the pinion problem?
Posted: Sun Mar 29, 2015 12:30 am
by rpollack
Yes - the corrected pinion gears are available on the motors
page.
Posted: Sun Mar 29, 2015 12:32 am
by helix_3
rpollack wrote:Yes - the corrected pinion gears are available on the motors
page.
Ordering two now, is generic superglue strong enough to hold a pinion on the shaft?
Posted: Sun Mar 29, 2015 12:37 am
by rpollack
I'll find out the type of loctite we are using and post that Monday. You'll need to carefully apply heat to remove the existing gear.
Posted: Sun Mar 29, 2015 1:26 am
by ednisley
helix_3 wrote:is generic superglue strong enough
Probably not, because cyanoacrylates aren't good for impact loads.
I'd vote for red Loctite, which is designed for exactly this sort of thing:
http://www.loctiteproducts.com/p/t_lkr_ ... ed-271.htm
Clean the shaft & pinion with acetone, apply Loctite
sparingly to the shaft, press pinion in place with one smooth motion, and get it right the first time, because you
will not get a second chance.
I'd use a pin in a drill press to keep the pinion squarely aligned with the shaft while ramming it down; doing that by hand seems fraught with peril.
Threadlockers are death to acrylic plastics: don't slobber the stuff on anything you care about.
Posted: Sun Mar 29, 2015 2:31 am
Loctite makes something called retaining compound. Its just like regular loctite but its not for threads. Its made specifically to hold things on shafts like this. Napa probably has it. Here is a link
http://www.henkelna.com/retaining-compounds-14963.htm
Posted: Sun Mar 29, 2015 11:56 am
by ednisley
jimc wrote:retaining compound
My Loctite kit has green 601, which (according to the label) augments slip fits and fills 3 mil gaps. Didn't seem like it'd work for a tight press fit like the pinion, but it's certainly better than nothing.
Soooo It's definitely time to update my collection: 648 sounds like the right hammer for the pinion job. Same green color, too!
Posted: Mon Mar 30, 2015 7:46 pm
by rpollack
We are using Loctite 609 (red, retaining compound)
Posted: Tue Mar 31, 2015 2:57 pm
by thecadman99
Thats great news.
I just ordered a couple
I used a GWS Micro pinion puller on my motor, and it removed the gear very easily with a touch of heat.
I may try soldering the pinion to the shaft...
Posted: Thu Feb 02, 2017 5:21 pm
by rsilvers
I heated it with a heat gun for a minute and it pulled off without any trouble with a pliers.
