Fan Shroud Question
kodbear
Fan Shroud Question
Post by kodbear » Wed Jan 27, 2016 12:20 pm
Hello everyone, first off I would like to start by saying hi. I have had a printrbot simple metal for over a year and last week I decided to make the HUGE upgrade to the m2 after a lot of research. I have been so happy with how good prints are coming off this thing little to no tweaking with the preconfigured s3d profile. The only issue is curl up on overhangs with the pla. I know usually its you running it to hot or you need more cooling or both. I have been running the 3d benchy boat and still I am getting curl up, I have lowered the temp settings to 210 and it didn't really change anything. I have seen there are fan shrouds out there and was wondering has anyone had luck with these? If so, which model did you use? If I am going about this in the wrong direction please let me know. Also I can post pics if need be.
Thanks
Vprints
Re: Fan Shroud Question
Post by Vprints » Sat Jan 30, 2016 6:15 pm
I'm using this one, and have been quite happy with it:
https://www.youmagine.com/designs/maker ... -fan-mount
-Vprints
Post by jsc » Sat Jan 30, 2016 7:27 pm
I use a fan shroud of my own design (for the dual), and it works very well. Reduces curl up, and I can get very good overhangs below 70 degrees, and perfect below 60. viewtopic.php?f=10&t=2020
See down in this monster guide for some more suggestions: viewtopic.php?f=8&t=2778
tldr: remove the fan guard, use a desk fan
You can also try a replacement 24V fan that is more powerful.
Post by sthone » Sat Jan 30, 2016 8:00 pm
Here's one I did for the Single V4.
Snips
Post by Snips » Mon Feb 01, 2016 9:00 am
This is the one that I made from a few designs that I found. One design I found blew the air to far behind where it was being extruded and this one blows closer and around the sides. I've seen much improvement since using this one.
http://www.thingiverse.com/thing:1305933
kodbear
Post by kodbear » Mon Feb 01, 2016 4:16 pm
Thanks everyone I will give them a shot and see which one works the best for me.
