3D Print surface that "flexes"
I am printing a large amount of small parts; is there a piece I can add to my glass that when done will flex, allowing the parts to "pop" off into a box?
Re: 3D Print surface that "flexes"
If you're printing in PLA, just let the glass cool and your parts should pop off easily.
Using PETG at the moment; I have seen some people recommends PEI; will that work for what I need?
Zebra plate. It's flexible.
Keep in mind, it might introduce a slight leveling issue that you need to be aware of how to fix - you can actually bend these, and you need to make sure they are as flat as possible (and clamped down) to use them.
viewtopic.php?f=10&t=2482
PEI also releases fairly easily once it is cool, but you might still have to pry them up a bit to get them started. It stays flat.
