Post
by insta » Thu May 11, 2017 5:32 pm
crazyg0od33 wrote:
I appreciate that, but it aint "operator error" when the overlap was apparently near the end of the spool the entire time. Letting go of the filament wont snap it under about 6 strands at different layers on the spool.
Yeah, it will
Retractions allow the tangle to shift down the spool.
pyronaught
Post
by pyronaught » Wed May 17, 2017 1:51 am
Yep, the cross under point just migrates back and forth on the spool and can go for hours like that. Usually you can hear that something is wrong though because the spool will stick and release as this is happening. It's easy to save the print by cutting the filament, pulling out the cross under and then feeding it back into the extruder behind the cut piece.
