The idea with my suggestion is literally to bring the parts that are about to warp up to their glass temperature, so the stresses will pull the plastic slightly thinner instead of off the bed. It's just a miniature version of an enclosed build chamber.theboz1419 wrote:The ABS juice worked the best, and probably would work with the enclosure temperature of 130°, as it did not warp as much. But, the face that is attached to the build plate needs to be perfect as possible, and ABS juice leave a surface that I don'tlike.
Insta- LOL, would 1350° be enough, hehe.
While my wife and baby are in Malaysia, I'm going to build a new enclosure using the heat gun as the heat source, and to control the temperature, I build thermocouple wifi controllers for BBQs that will control a blower and servo(if needed). I will connect the controller to a SSR and I will be able to turn of and on the heat gun to control the heat and have a servo controlled a vent, if needed.
Need help with a case.
Re: Need help with a case.
